Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...with companys cutting back on training, lack of true support by makers of software, the forums are a great tool in your cyber-toolbox...."
Geography
Steve107 (Materials)
8 Sep 09 6:33
I use a poly/iso mix to produce product. On occasion product appears to have "skin" that is seperated from the product.  I use an in mold release mixture from Chem Trend 6 parts release 13211 and 1 part MR-515-H. In mold paint is Bay One's IM400 mixed with our paint.  Molds are painted after release is applied and before pouring Iso/Poly mix.  Iso/Poly is heated to 85 degrees.  Process is in a temperature controlled environment.  Molds are made of Alumilite.  Plese see attached pic.   Any suggestions?
patprimmer (Publican)
8 Sep 09 8:36
I will take a wild guess that you are casting with 2 pot polyurethane and a gel coat.
Has this worked before, if so what may have changed.
Have you requested help from your material suppliers.
Pat
See FAQ731-376: Eng-Tips.com Forum Policies for tips on use of eng-tips by professional engineers &
http://eng-tips.com/market.cfm
for site rules
coatingengineer (Chemical)
27 Oct 09 21:13
Hi, Steve.
Sounds like a compatibility issue between your mold release and paint.  Even if the problem is occasional, only.
Have you contacted either supplier?  Discussions with them could be most valuable.  For example, could humidity be playing a role in surface catalysis?
Best wishes.
William Gunnar
http://www.IndustrialCoatingsWorld.com
Close Box
Join Eng-Tips® Today!
Join Us             Close
