Load distribution
Load distribution
Load distribution
thread384-165178: vibration levels with spring isolators
How do we hand calculate the static load distribution (with known mass, inertia & CG) at each mount (know stiffness and locations relevant to CG) support manually for a 4 mount support system? Static indeterminate for more than 3 supports and force & moment balance does not help!
I was interested to have static deflection closer at each mount location.
Thanks in advance
Jeyaselvan
RE: Load distribution
Draw it in side view, and in front view. the location of the rigid body is controlled by CGZ, and pitch and roll. This also gives you the deflection of each mount, and hence the force it supplies.
That should allow you to write enough independent equations to solve it.
What you have done is to invoke geometric compatibility as an additional constraint, I can't remember what the structures boys call it, but that is how you solve simple redundant systems.
Cheers
Greg Locock
SIG:Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips.
