Removing a decal
Removing a decal
I am using SW 2009 and have applied a decal to a certain surface. I would like to remove the old decal and put on a different decal. For some reason, I am having trouble removing the old decal. Is there a way to do this? Also, once you have applied the decal and closed the model, it doesn't seem as if you are able to edit (or resize) the decal. Just wondered if there was a setting that allowed removing and editing of existing decals?
Kevin
Kevin
RE: Removing a decal
Dan
www.eltronresearch.com
Dan's Blog
Kevin
Dan
Dan's Blog
