Dear All, I am dealing with quit
Dear All,
I am dealing with quite number of Dewatering problems in tendering stage as well as for working jobs in varied type of soils(sand/Clay, Rock).
I have a problem in deciding the thickness of aquifer that should be taken in the standard formulae(For unfined and unconfined),because the Bore hole details may not be available to the full depth of aquifer(example, a sand layer of infinite depth and we do not know where the impermeable layer like rock is there).
In those situations what should be the thickness of the aquifer should be taken ,for dewatring of say 6m in aquifer?
Please enlighten me in this regard.
Thanks and Regards
Hariharanath.K
L&T,ECC
Thanks and Regards
Hariharanath.K
L&T,ECC
RE: Dear All, I am dealing with quit
Good Luck, and gimme' a holler if you need anything else.
Best regards,
R.A. Hassett, P.E.
rah1616@hotmail.com
