Adiabatic Temperature Rise-Exothermic Rxn
I know the way to calculate the adiabatic temperature rise: Heat_of_Rxn/Cp. However, I have run into a bit of a sticky wicket. I need to calculate ATR of a fluid bed reactor with a large amount of metal catalyst. The heat capacity of the liquid and the catalyst are significantly different. Any advice on how to proceed. The heat of reaction is around 2000 kJ/kg of product and the reaction mix has a heat capacity of around 4 kJ/kg∙°C.
RE: Adiabatic Temperature Rise-Exothermic Rxn
