Design of 2 Phase Separators
Currently designing a 2 Phase Separator.Can anyone please help me with materials,Literature,Go Byes that will assist me to generate from the mechanical perspective, the following documents:
1.Specification
2.Data sheet
3.Calculation sheet
Really appreciate it.Thanks
1.Specification
2.Data sheet
3.Calculation sheet
RE: Design of 2 Phase Separators
All you really need is in GPSA and ASME VIII Div. 1.
In the huge majority of cases I have seen, it ends up being SA-516-70N and related material with the wetted surfaces often coated with an epoxy primer like Devoe 253. The vapour outlet(s) might have a mesh pad (demister) inside the vessel, typically SA-36 angle supporting 316 SS 6#/ft^3 to 12#/ft^3 by 6" thick mesh.
Standard practice lately appears to be to fabricate all connections for three phase separation and dress the unit (instrumentation and bridles) for two phase operation.
SNORGY.
