From in to mm
From in to mm
From in to mm
Hi All,
I was assembling some components together from parts that originate from different sources, and I realised that they are in different units of measurement.
Does anyone know how to change the units of measurement for the whole part?
Best Regards,
Biomak
RE: From in to mm
Do this:-
set up,parameters,units,new:
you will get a window where you can type your custom unit.
select all the required units you want,click o.k:
select again the custom unit,set.
you will get two choices,Among them select:
intrepret existing numbers,o.k
cheers!
RE: From in to mm
Create a map key from SETUP->UNITS->..... and aplly it to each part.
-Hora.
RE: From in to mm
Thanks cranekiran and Hora. It was easier than I thought.
Cheers,
Biomak
