Removing sludgey buildup inside a compressor bundle
Any recommendations for cleaning a compressor bundle that has a sticky, heavy layer of film build-up inside that is causing unbalance symptoms? It's not a parafin based substance as it is like a slushy black toothpaste. I've considered injecting xylene into the suction line upstream of the bundle.
All advice welcome.
All advice welcome.
RE: Removing sludgey buildup inside a compressor bundle
you also should check how it got there. if it got there due to faulty seals you better change the seals to prevent it from reoccurring.
Johnny Pellin
