HNBR - Compression
HNBR - Compression
Does anyone have mechanical property data for this rubber type? I want to know the following based on these design data:
-- Rubber element OD-50,8mm, ID-35mm, Length-50mm
-- After Compression it is squeezed together such that it expands into a pipe with ID 52,5mm
Q: What is the new length?
I only need a rough approximation
RE: HNBR - Compression
