API 1104 WPS's and AWS Filler Metal Classification
This is one of those "ask six different people and get six different answers" questions!
Section 5 of API 1104 (Welding Procedures) requires you to requalify a welding procedure on material 65 ksi and greater if you change a filler metal AWS Classification.
My question is:
Would changing from E8018-B2 to E8018-C3 be considered an AWS Classification change? Or are they implying you would only need to requalify if you were changing from a E8018 to a E9018?
Thanks in advance,
Mark
My question is:
Thanks in advance,
Mark
RE: API 1104 WPS's and AWS Filler Metal Classification
Based on the foregoing, one would conclude that the indicated classification difference is, in fact, a change of classification. The underlying reasoning is explained in the note under 5.4.2.2 of API 1104 which is particularly pertinent to high strength linepipe steel.
Steve Jones
http://www.linkedin.com/pub/8/83b/b04
Yes.
That is also a change in classification.
Steve, thanks for the section in A5.5, that makes this issue crystal clear.
Steve Jones
