Leader modifications
I have created several ID Symbols on a drawing page of an assembly and I would like to add one or two elblows to several of the leaders in order to unclutter the actual drawing view. How to do so?
RE: Leader modifications
I should have added. NX 5.0.
Thanks.
You have to create new leaders. Using Edit>Annotation>Leader you should first remove the old leader by selecting remove and picking the leader. Next you select Add, pick the annotation or symbol that you want to add the leader to then pick the object to attach the leader to then screen pick locations for the elbow points in your leader and hit apply to finish and create the leader. You may have several elbow points if you wish.
Best Regards
Hudson
www.jamb.com.au
Nil Desperandum illegitimi non carborundum
