Carbon fiber telescope tube
Hello, everybody.
I am planning to build myself a 80mm refractor telescope and I want to make the tube from carbon fiber composite.
What type of lay-up should I use for the composite for maximum dimensional stability? I did't find a clear answer searching in the composite books that I own, so I'm hoping that I may find some help here.
I'm leaning toward a quasi-isotropic, balanced and symmetric laminate. I will use slippage-resistant 210g/m2 carbon twill and for now, the stacking sequence is [0,+-45,90]s. I will make two halfs of the tube by using hand lay-up (female mold) and then vacuum bagging. The two halfs will then be bonded together with the internal baffles.
Any help will be greatly appreciated.
RE: Carbon fiber telescope tube
Will your tube have a taper? If so it will be impossible to keep the weave going orthogonal. You may want to consider using uni tape.
If I were making this I would wrap a single ply around a sacrificial cylindrical mandrel multiple times then place the wrapped mandrel in the 2 halves of the female mold. I hope this helps.
Rob Stupplebeen
Twill probably won't need 0 and 90 & + and -45 or balance in terms of warp-side down vs. weft-side down. Just something like 0/45/45/0 all the same way up should do. In theory you could use just 0/45, but it's probably unwise, as rstupplebeen says.
Bear in mind that making two halves will cause each half to have more curvature than the tool due to spring-in, especially from an elevated temperature cure (even an RT cure will spring due to resin cure shrinkage). True for male and female tooling. This will happen even if the laminate has through-thickness balance.
The tube doesn't have any taper, it's a constant thickness cylinder. When I was refering to dimensional stability, I was thinking thermal stability, between -15*C and 30*C. I don't want the tube to bend or twist with the temperature variation.
I cannot use prepreg, so with the male-female mold method, I don't know how to control the fiber volume ratio (usually I use vacuum consolidation).
I also will let the part cure at room temperature to avoid any post curing deformation or the deformation of the tool with temperature.
The exterior finish of the tube is important (I will apply only clear varnish), the interior is not.
After reading your posts, it seems I would be better off with a UD ply with the fibers along the tube length, wrapped around multiple times. For the finish, it would be ok to wrap a twill ply on the outside and one on the inside of the tube to keep it symmetrical?
After wrapping the fabric, the ends of the fabric must be one above each other? I am thinking if they aren't, the tube doesn't have the same thickness all around.
Off topic and just out of curiosity, how do you get the prepregs/fabrics/resins/expendable materials, etc.. for low volume DIY constructions?
The rest I buy it from online specialized shops (I'm not sure I am allowed to post links to their sites) or from local composites distributors.
Mike Halloran
Pembroke Pines, FL, USA
Of course, there are many others.
Provided this is done, you can mix UD and woven. If you do not make the laminate quite the same around the tube as along it in terms of fibre direction, the CTE wiil be different around the tube than along it (duh!).
Moving to UD will give you the opportunity to make the CTE a bit less than with woven, if it's critical.
If you make the layup something like twill@0°/UD@0°x4/twill@0° it should come down to about 1.3 microstrain/K along the tube (and maybe 8 microstrain around it). If you go to an expensive high modulus fibre it'll come down even more: Toray M55 as the UD might give 0.15 microstrain along the tube.
Mismatching the CTE of woven with 0° UD would make it a bit more likely to get interlaminar cracking at the laminate edge, even with an RT cure.
For a thing like this tube, it's ok to carefully butt the plies with no overlap. You only really need to overlap things if strength is a major issue.
Thanks for the links.
The most important thing for the tube is that it will not bend with the temperature variation. If it does, the telescope looses collimation (allignment of the optical axis) and it must be collimated again and again. If the tube length or diameter vary with the temperature it's not so critical because you can refocus (however, these variations must be as small as possible).
Given what has been said in the above post, I think I will go with one layer of twill rolled multiple times on an aluminium mandrel. At both ends, the tube will be bolted on some flanges and the interlaminar cracking at the free edges will make things worse.
I began some testing with some aliminized fiberglass twill (the only fiberglass fabric I have with no silane sizing) to see how the fibers allign when rolling the fabric on a mandrel. Right now I have problems with vaccum bagging wich causes some wrinkling on the tube.
I think I will not use vacuum on this project. I will try to make some "poor-man prepreg" by impregnating some fabric with the just amount of necessary liquid resin and then wrap it very tight around the metallic mandrel. Then I will wrap some peel-ply around it to be able to sand the exterior without damaging the fibers and then wrap some bagging nylon very tight. After that I will cure the thing at temperature and I hope the expansion of the aluminium mandrel will strenghten the fibers even more.
I'll let you know how it worked out and post some pictures.
You can apply a final layer of peel ply the same way so that you end up with a clean outside surface without resin ridges.
The result can be seen in the pictures. The tube is just out of the mandrel and it must be sanded and polished.
I gave up using vacuum consolidation for this project because it kept making wrinkles no matter how tight I was wrapping the fabric.
Now I can make the final tube using carbon fiber and an aluminium mandrel.
Thanks again for the ideas.
He said that he just bought in pre-made carbon tube and didn't much worry about the detail for tubes up to 200mm. He said they are strong, stiff, dimensionally very accurate and "have a thermal expansion coefficient 1/100th that of aluminium"
gwolf.
