What is two-pack epoxy?
Can you simply explain to me what does the "Immersion-grade two-pack epoxy" means?
what does two-pack means here?
Pipeliner Dude
Offshore Pipeline Engineer
RE: What is two-pack epoxy?
Second pack: hardener
Generally, the third pack: the thinners, is ignored.
As to whether the paint is 'immersion grade', that should be confirmed either by satisfactory prior experience or by laboratory test results.
Steve Jones
http://www.linkedin.com/pub/8/83b/b04
http://www.dstan.mod.uk/data/80/179/00000200.pdf
hope this help u
S
Corrosion Prevention & Corrosion Control
