Spliced Center Columns
I am having trouble sourcing a center column for a 50' tall tank that is long enough in one piece(24" std wt pipe).  I have heard that our old tank expert did not allow splicing of the tank center columns.  I would think that with proper testing of the weld and insuring the column remains straight this shouldn't be a problem.  Does anyone have any experience with splcing tank columns?  Is this a no-no in the industry?
Thanks for any responses.
RE: Spliced Center Columns
It's not uncommon.  The main concern is straightness, not so much weld inspection.
Are there any Codes that give guidlines on straightness of the columns?  AISC?
Splice away - it is very common.  Be wary of splcing with a plate (some might think that two fillet welds are easier to do than a butt weld) since it creates trouble for cleaning in the future.
If you are concerned with the straightness, consider the deviation of the column axis from the compression axis at the ends as inducing a bending moment with the deviation being the moment arm. Then combine the axial and bending stresses by addition or sum of squares and compare to allowable. For a column to need splicing, it should be long enough for buckling to be the failure mode and the resulting stress reduction enough to overcome weld efficiency at the splice.
