Tempering of Steels
Tempering of Steels
When Steel components are tempered is it possible during the heat treatment process to allow too much time soaking at the target tempering temperature?
RE: Tempering of Steels
Yes, it is possible. Standard tempering times for most carbon and low alloy steels are 1 hour/inch at tempering temperature with slight incremental increases in time based on thicker components. If you remain too long at a specific tempering temperature you will reduce strength properties from carbide coarsening.
would this effect be applicable to PM parts also?
Although, I am not experienced in PM part processing, I believe the parameters regarding time at temperature would also apply to PM parts, based on what I have seen in literature.
Plymouth Tube
I was also wondering if excessve time at temperature could have maybe a detrimental effect on the dimensional stability of small components?
