Question on value of force in structural calculation
Hi everybody
I have a basic question.
Suppose I need to provide a support for a section of piping which have valve and some instruments on that. The weight of valve and instruments in catalog are given as 75 kg. So do I need to consider it as weight of valve and in calculation use 75 N for force or should I multiply by 9.81 to convert it in weight (W=mg) and then use as force in calculation?
Similarly if the fluid density is given as 1200 kg/cubic meter is it mass density or weight density for the purpose of calculations?
Thanks in advance
Thanks in advance
RE: Question on value of force in structural calculation
"Keep your units consistent"
If you're designing in metric, keep it in metric.
If your're designing in imperial, keep it in imperial. As many times as they beat it into our brains at school, it makes complete sense to me now.
The essence of my question is that the value given in vendor catalog under heading of "weight" as 75 Kg is mass or weight?
If I follow unit then it should be mass. If it is mass then definitely I won't get the weight as 75 N.
And if it represents the weight then it should be 75 N (why it is mentioned in kg)unless it doesn't mean Kgf implicitly.
Till now in all text book problems I got either mass or weight explicitly so never faced such problem.
I am just thinking of a situation to solve this problem.
I do not have anything to design.
Would you like to get hired in case I need someone
I am very confused on this that's why seeking help from knowledgeable persons.
It is common for us Americans, to use mass as weight. We know it is not interchangeable, but honestly, I'd take 75kg and multiply by 2.2 to get my weight in lbs, when actually, I got it in lbm.
Watch your terminology and units. Kilogram is a unit of mass. Newtons and pounds are units of weight. If you get confused about this, you will get wrong answers. Stay away from lbm and kgf.
w = mg = 75kg × 9.81m/s2 = 734 kg.m/s2
A kg.m/s2 is a Newton.
1lb equals 4.45N, not .453kg!
if the unit weighs 75 kgf = 165 lbf = 734 N
if the unit's mass is 75 kg, then it's weight is 735 N = 165 lbf
ie it doesn't matter !
where's the mistake !?
Some of the above is correct, some not. I won't try to straighten it out.
Structural engineers who use the SI system usually simplify mass to force conversions by just using multiples of 10 to get to force. Thus, for our purposes, 100kg equates to 1kN force. 1000kg is 10kN or 1 tonne. The fluid with density 1200 kg/m^3 gives a pressure of 12kPa if applied over an area. This way simplifies things for structural design, and is only a little bit conservative.
Mass and weight are not interchangeable, but many people use the terms as if they are.
"weight 75kg" means "mass 75kg".
DaveAtkins
I feel the problem is not the consistency of units as long as I am working in SI. (I am not much familiar with USCS or FPS or any other for that matter).
My basic confusion is the engineering aspect of mass and weight. I am pretty clear about difference between mass and weight in terms of physics.
To further simplify my question generally I measure my "weight" on weighing scale and it reads 50 "Kg". So it this 50 my weight or my mass? And if I want to design a chair for me to sit should I use the load as 50 (considering the measurement as weight)or 50 x 9.81 (considering the measurement as mass)
If instead of weighing myself on weighing scale I weigh on a balance scale would i get different value?
The unit will identifies itself. If it said 50Hz what would that mean? Or 50 Volts?
If your supplier says weight 75kg, to me that means mass of 75kg equal to a force (on earth) of 734N. Which is your static load. If they said weight 75N then that is your static load. If they didnt give you any units, and just said 75 then your stuffed.
You sound vague and confused. "Weighing scale" does not mean anything to me.
A spring scale measures the force due to gravity. This is weight, in units of Newtons and pounds.
A balance compares your mass with that of some standard masses. The units are kilograms and slugs.
When you do your calculations, try doing a unit balance. If you are doing this wrong, your units will not make sense, and you will know you have to fix something.
On the other hand if the object is weighed on balance the value of the mass against which it has been balanced will give me the mass of that object and to include that in calculation as static load I need to convert that mass into weight (force).
And obviously I will have to contact the vendor to know if the shown value on the catalog is measured by spring scale or balance. I would consider myself lucky if he knows that.
Otherwise better to consider the value on catalog as mass convert to weight and do the calculation. Some conservatism may come in the results but in view of all uncertainties it would be acceptable.
Any other thoughts are welcome.
Thanks all for the discussion.
i think i was correct in pointing out that a weight of 75kg is equivalent to a mass of 75kg (pretty obvious when you express it that way !), the force is 736N.
If the "weight" is in kilograms, it is mass, and should be multiplied by "g" to get to force.
If the "weight" is in pounds, it is a force, and no multiplication needs to be done.
It doesn't matter what type of scale was used. If you put a 5 pound bag of sugar on a balance scale, the corresponding object that balances it will have a weight of 5 pounds. They also have equal masses, but nobody wants to think about slugs.
Going back to my schooldays I seem to remember that a pound is a mass but a poundal is the force, but nobody says poundal and confusingly calls the force pound, the same as the mass. Numerically though, one is different to the other. I'm just glad that here in the UK we switched to metric where mass and weight have conveniently different names and nobody gets confused.... or do they?
More slugs please.
corus
You stated:
That statement may be true at sea level, but not on a mountain top, not in a valley and certainly not on the moon.
BA
you're quite right, but i'm pretty sure that 99.99% of engineers would use 32.174ft/sec2 (or 9.807m/sec2) for "g".
and if the application was for extraterrestal then the OP would state so (probably not at first, but usually in a later post "oh, btw, this is on the moon")
I talked about spring weigh and balance because when I go to purchase any commodity it is measured in kg. The ref weight they keep on one side of balance say 1 kg and the commodity on other side say sugar.
I wanted to know whether that 1 kg ref weight represents mass and gives mass value or it is weight. and I will not get same "numerical value" if i compare an object with a "mass" and then weigh on spring scale unless spring scale is calibrated to show mass reading.
It is correct for lbm and lbf on earth since coincidentally both are numerically equal on earth.
When weight is given in pounds there is no need to think about converting to force because pound (mass) and pound (force) both are numerically equal on earth. Hence same numerical value shall be used as static load.
But when weight is given as Kg it implies Kgf and we need to multiply by g to convert to force to use as static load.
The confusion arouse due to dropping of 'f' from Kg due to convention. Weight 27 Kg means 27 Kgf.
The following vendor site gives weight in pounds (without mentioning lbf or lbm)and Kg.
http:/
If I compare both values then it comes that the value in Kg is weight in kgf and value in pounds is also weight.
This lets me deduce that both values are in force units lb in lbf and kg in kgf but f is omitted for simplicity.
thats why
27 kgf becomes 27x9.81=264.87N
and 60 lbf equals 60x4.45=267N
Your grocer is not doing acceleration calculations, so it is harmless for them to confuse units.
When I was in college, we learned English units and metric. We learned one set of equations for acceleration equations using force units, and another set of equations using mass units. You can analyze force using lbm and kgf with gay abandon if you select the correct set of equations every time.
There is a simpler way, less likely to result in mistakes.
m = w/g
f = ma = (w/g)a
m is in units of kg or slugs. In English calculations, if you insert (w/g) for mass, you never have to see a slug.
w is in units of N or lb.
"when weight is given as Kg it implies Kgf and we need to multiply by g to convert to force to use as static load" ... no, no, no. the "f" in kgf stand for force; when weight is given in kg (or kgf) it is a force and we Don't have to multiply it be anything to get force.
ussuri, "To me 1kg = 2.2lbs, both units of mass" ... absolutely correct except for the last word, which makes it absolutely wrong. a 1kg bag of sugar is equivalent to a 2.2lb bag of sugar ... it's weight not mass. i'm guessing you're in europe or some other place that hasn't seen the imperial system ... pounds have been used for weight for an awful long time, longer than N (or kg).
the problem is the metric system introduced the kg as a force (i guess the prols couldn't handle a Newton) and messed up a very nice system. however, the saving grace is that the weight of a 1kg mass is 1kgf (so long as your g = 9.807m/sec2). the only time to be careful is when you need the mass of something, like for momentum calcs, or mass flow rate.
It should be:
"when weight is given as Kg it implies Kgf and we need to multiply by g to convert in 'Newton' to use as static load"
sometimes people are confused (lazy?) and say "weight" when they mean "mass" (and vis-a-versa).
That is wrong wrong wrong. Pound is a unit of force. The corresponding mass has the unit "slug."
This is also wrong. Kilograms are a unit of mass. Pounds are a unit of force (weight is a force). A 1kg bag of sugar has the same mass as a 1lb bag of sugar. They also have the same weight. But that doesn't mean the two numbers with different units are the same. The weight in force units of a 1kg bag of sugar is 9.81 N (Newtons). 9.81N and 2.2lb are the same, and both are units of force.
Back to the original question:
Kilograms measure mass.
Pounds measure force.
To get the force induced by a 75kg mass (on earth, at sea level, when you hold your nose just right), you multiply it by g. The force is 75*9.81=736N.
This should have been resolved with the second post.
But Kg implies force when given as weight that's the crux of discussion.
rb1957, pound is a unit of both mass and force. I disagree that pound as a mass is 'absolutely wrong'.
Thankfully, being British, and not old enough to remember imperial I do not have the problem of sorting out pound-force and pound-mass.
BA
when was the last time you were in a store ? buying a kg of sugar ??
I started this discussion to clear my doubt why a vendor gives a mass unit in the heading of weight and whether he means that given value represents the mass or weight?
Please see the website for my doubt:
http:/
Now after reading the point of views of so many persons and probably from different geographies of earth where different system of units are followed I got more insight in this topic which I want to outline:
1. Before this discussion I used to think pound is unit of mass.
2. In USCS (United States Customary System) pound is unit of "Force" and Slug is unit of "Mass". Where as in FPS unit system pound is unit of "Mass"
So depending upon system of units it represents both.
But on earth co-incidentally pound force are pound mass are equal.
2. We get groceries or commodities on weight basis so if i purchase 1 pound sugar it means that sugar "weighs" 1 pound (lbf) similary where things are sold in Kg it means the weight of sugar I purchased will be 1 Kgf and for convenience they omit 'f' and if I convert this in newton it will become 9.807 N
1 lbf sugar = 4.45N
1 lbm sugar = .453 Kg of sugar (mass basis)
weight of .453 Kg = .453x9.807=4.4425 N
On earth due to the value of proportionality constant of Newtons second law equation F= Kma, lbf and lbm are equal.
3 The direct equivalent of Kg (mass) is NOT Pound (mass). It is Slug.
4. If you are using mass in Kg or Slug then you can directly use the equation F=ma (K is equal to one in these cases) but if you are using mass in pound you have to use F=kma.
5. If a vendor writes weight as 27 Kg he means 27 Kgf to get the value in newton it should be multiplied by 9.807 for those who work in N. For those who work in Kgf as force no need to multiply by 9.807.
If weight is given in pound it is basically pound force.
If anybody uses USCS there is no confusion since he is incorporating force in his calculation.
Those who work in FPS taking pound as mass if they convert it in force say pound force they will get the same value.
For example 60 pound mass on earth will be 60 pound force.
I don't buy sugar. It's not on my diet.
BA
1kg * 9.8 m/s^2 * 1 N*s^2/kg*m = 9.8 N
(Mass * g)/gc = Force
Going against the grain, I'm going to have to say I like the FPS system better... 1 = 1! (as long as you are religious about indicating lbm vs lbf it works very nice).
On the subject of vendor data-sheets claiming "weight" in kg. They do that. Sometimes I think the datasheets are produced by the sales department. I would hope you can figure out by the factor of 10 what is meant.
