Unit conversions for specing flow meter.
I am just stuck I guess. This is my first time shopping for a flow meter and I have hit a wall with units. This is for a leak tester. I know my max flow is 20kg/h but for finding a flow meter I need to figure out an acceptable minimum flow. I do not have a minimum flow rate only the leak rates I need to be able to detect. Those are in mbar*L/sec, cc/sec, and Pa/sec. I fluid is air at room temp. How do I convert these leak rates to kg/h to spec a minimum flow requirement?
RE: Unit conversions for specing flow meter.
TTFN
