Why is ASTM A694 F65 steel not listed in ASME II Part D?
Why is ASTM A694 F65 not listed in the allowable stress tables of ASME II? As far as I know this is a standard material used for flanges.
I wanted to perform some calculations on a bolted flange connection. The material is specified as ASTM A694 F65. I was reluctant to use the alternative approach listed in ASME II Appendix 1, since there may be other reasons why this material isn't listed.
Thanks for your help, any comments are welcome.
RE: Why is ASTM A694 F65 steel not listed in ASME II Part D?
1. The only reason I can think of that this material is not endorsed by Section II is because there has not been use or need for it in boiler/pressure vessel service.
2. Take a look at ASME B16.5. I found no such material as being standard material.
The flange that I am looking at is an offshore compact SPO flange, I have now found alternative design rules in NORSOK L-005. Annex D of the NORSOK code gives structural capacity ratings, stated to be in accordance with ASME VIII Div 2 App 4 & 6.
ASTM A694 Grade F52 is listed in the NORSOK code as a typical material, however grade F65 is not. I couldn't find any mention of ASTM A694 in ASME boiler and pressure vessel code. I'm pretty confident F65 is used for ANSI/API flanges. Someone else may be able to confirm this?
Steve Jones
http://www.linkedin.com/pub/8/83b/b04
I can confirm that the F65 material is videly used for flanges, hubs and other forged shapes. The ASTM standard gives you material values (see my thread http://www
The material is not listed, thus you need to treat it as "non listed material" (do not know all details for this approach).
We've used this material in combination with both ASME B31.8 & ASME BVP VIII div.2.
