Trying to apply a force to a hole
Hi
I am new here and to algor. I trying to apply a force to a hole. I want to use like a bearing load. well that is what it is called in others software. I have tried to spilt the surface in the hole and applying the force, but I get a very high stress in the hole split. I think I have to use variable surface load, but I can not get the load right. And I have tried getting help from Algor, but nothing there after autodesk toke over. anyone can help?
Thanx
Thanx
RE: Trying to apply a force to a hole
To create the archive, just open the model in FEMPRO. Go to File: Archive: Create and select "without results" since you probably don't have any yet anyway.
Sorry about Algor's tech support...I was concerned about this when I found out Autodesk bought them and I heard about some of the reorganization.
I will do that. It is a brick element, imported from 3D CAD. Just part with two holes, one is suooprted and the other applyed a force tension. (from a shaft)
just modify the surface number for the entire area???? How do I do that?
Ib
Garland E. Borowski, PE
Engineering Manager
Star Aviation
