Changing Section segments from 90 degrees
I am new to UG and have searched everywhere I can think of to modify the default section segment from 90 degrees to a value I can enter. My problem is trying to take a section view through a center of a hole at 90 degrees, then through a slot that is angled at 3 degrees to get a true interior dimension, then back out through the bottom of the housing. I have tried to tweek each segment by moving them in the Section line edit mode. I can almost get the line to center on the slot's centerline but it is not exact. I hope I have expalined this well enough. None of my drafting notes seems to have listed anything I can use.
Thanks!!!
Thanks!!!
RE: Changing Section segments from 90 degrees
Insert -> View -> ...
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
Tim Flater
Senior Designer
Enkei America, Inc.
www.enkei.com
Some people are like slinkies....they don't really have a purpose, but they still bring a smile to your face when you push them down the stairs.
Tim Flater
Senior Designer
Enkei America, Inc.
www.enkei.com
