Different layers in title block in Inventor
I am working in Inventor 10. Have a title block that I input the title by going into "iProperties", then "Summary". I then input the title.
Is there a way to have one line of the title on one layer, then another line on another layer?
This way, at times, when plotting, I can turn one line of the title off by turning that layer off.
Thank you.
Thank you.
RE: Different layers in title block in Inventor
Maybe someone that has used IV10 could say for certain if this is possible.
David
1. You have two lines for your title in your title block, each line consisting of a different iProp.
2. You want to be able to turn off the print option for a single line/iProp via layers.
If this is the case, and it is possible in v10, you will need to edit the title block template. Select the title block from the model tree and change the attribute that corresponds to the iprop you want changed to a different layer.
I don't have access to Inventor right now as I use CATIA now at my job so I can't verify this, but if it is possible you will need to make the change there. Also if you want this to be a persistent change in all your TB's you need to edit the drawing template file itself and save it, changing the drawing you are currently working in will only effect the current drawing.
David
Actually, he currently has a single iprop that spans 2 lines and wants the wrapped row on a different layer which is not possible.
