Hole Series vs Hole Wizard
I'm having a problem properly calling out threaded holes in a drawing.
I have two parts, they bolt together. When I use Hole Series to create the clearance hole and the threaded hole at once I am unable to properly call out the thread in the drawing. In the drawing, using the Hole Callout annotation, I get the drill diameter (not thread diameter) and the depth. I seem to be unable to change that other than manually typing in the thread callout (which I think is a bad idea).
If I create the holes using Hole Wizard instead the Hole Callout seems to work fine. I get the proper thread diameter and depth.
This seems like a pain and a potential for problems as the clearance hole and the threaded hole are no longer linked together in Hole Wizard like they would be if it was a Hole Series.
Am I doing something wrong here?
best,
Dan
best,
Dan
RE: Hole Series vs Hole Wizard
Matt Lorono
CAD Engineer/ECN Analyst
Silicon Valley, CA
Lorono's SolidWorks Resources
Co-moderator of Solidworks Yahoo! Group
and Mechnical.Engineering Yahoo! Group
