Parsing FIL file with Python
Hello all,
I am looking to access the .FIL file instead of going through the .ODB. The Abaqus documentation says that each entry is 8 bytes long whether it's a string, float, or integer.
I am trying to used the struct module to convert the binary. I am unsure what format to use to read 8 byte integers.
For a first step I am simply trying to print the record length and record type key - the first 16 bytes of each entry.
import struct
sFileName = 'shellMeshStatic.fil'
f = open(sFileName,'rb')
for x in f.readlines():
q = struct.unpack('<qq',x[0:16])
print q, len(x)
f.close()
I seem to be getting garbage. Has anyone done this before? Any help would be great.
-Ryan
import struct
print q, len(x)
f.close()
-Ryan
RE: Parsing FIL file with Python
www.Roshaz.com
I am writing some utilities to analyze post-buckling of stiffened panels. The models are generated as Nastran files from another code. I am trying to do the pre and post processing with a single IronPython application with a GUI interface designed using the (free) SharpDevelop IDE.
On johnhors suggestion, I am parsing the ascii file instead. It is pretty straightforward parse the ascii FIL since you can physically see how the data is patterned.
TOP
CSWP, BSSE
www.engtran.com www.niswug.org
"Node news is good news."
www.Roshaz.com
I know that. But he was reading a binary file. Only a hex editor will let him see what is in it. I agree exporting as ascii makes a lot more sense.
TOP
CSWP, BSSE
