Asphalt class, lift thickness and use of prime and tack coats
I'm finalizing asphalt pavement design for site in Connecticut that will be used for storage of dumpsters - so there is pretty heavy vehicle loading as well as impact loads from dumpsters being dropped. I have geotech recommendations for 10" subbase and 2 courses of asphalt to equal 5". My question is, what class asphalt to use for the two courses, what lift thickness to use, and whether to use prime and tack coats.
I've heard that lifts should not exceed 2", but I see other guidance that suggests otherwise.
Thanks much!
Thanks much!
RE: Asphalt class, lift thickness and use of prime and tack coats
Use concrete.
Whether 5" pavement & 10" subbase is enough depends on the subgrade. Due to frost concerns in our locale, subbase is usually thicker (12" to 48")and asphalt thinner, often 2" asphalt & 2" base course. So 5" sounds like a lot to me. There have been discussions here whether prime coat & tack coat are worthwhile, I think not worth it unless there are delays & exposure to weather, etc during construction.
The 10" and 5" were my geotech's recommendations based on the pretty compact subgrade and heavy duty use of the area, and I gotta go with them. Any concerns about using a 3" coarse asphalt lift as base (compaction issues?) and a 2" surface asphalt lift?
There does seem to be an ongoing debate about tack coats. From my former life as a boat builder, when I always pre-wet materials to be bonded, I'm leaning toward using the tack coat to fill the surface of the substrate and lock the new material to it.
Thanks again.
For the type of mix, check with your state DOT for what they would use for heavy traffic to avoid rutting. Then, you need someone to test that you get that mix and the density the state would require. Typically a materials testing firm would do the job of the inspection.
Density of asphalt mixes makes a heck of a difference in how they behave.
On the design thicknesses, I too think it is over designed.
As for tack coat, I would recommend it. You will have a lot of twisting, stopping, turning movements on this pavement, so good bond with the base is essential to keeping the shoving problem in check.
Bill
If the contractor has any trouble getting compaction, they'll point the finger at you for specifying the lifts too thick.
Tack coat should be used for the reasons Ron said. Prime coat is generally unnecessary unless the base course has been sitting for a while.
Using 3 lifts instead of 2 lifts also increases the cost of the laydown by 50%. Owners tend to respond to that sort of stuff and will overrule you based on the costs. Since the contractor can point to an established "standard" (that being the DOT), you have little basis to refute the process.
