Polyethylene pipe Test
Hello everybody.
I'm looking for alternative methods for leak and pressure tests in polyethylene pipelines (PE pipes), rather than classic hydrotest.
I was reading about gas tracers, but they are a very time-consuming alternative.
The acoustic test is appropiate for this material?
Is there an alternative method por pressure & leak test in PE pipes?
Thanks.
Thanks.
RE: Polyethylene pipe Test
"Pumping accounts for 20% of the world's energy used by electric motors and 25-50% of the total electrical energy usage in certain industrial facilities."-DOE statistic (Note: Make that 99% for pipeline companies) http://virtualpipeline.spaces.live.com/
