Standard 250 grade flat bar at 400degC non pressure part
I intend to use standard 250 grade 32x5mm flat bar as baffles in a jacketed vessel, with thermal oil at up to 400degC in the jacket, it will not be a pressure part or under any significant load. Can anyone for see any problems with this, and should I use BQ plate?
RE: Standard 250 grade flat bar at 400degC non pressure part
Make sure to cover your backside, 400 deg C could be a bit too hot...
cheers,
gr2vessels
