Gas Expansion Turbine Generator
Hi Everyone,
We have a number of pressure reduction stations in our Natural Gas distribution network. Inlet pressures of around 3.8 mPa are cut down to around 1.9 mPa by the pressure reduction station using throttle valves.
I am currently investigating the use of Expansion Turbines in place of the throttle valves. The flow and expansion of the gas due to the pressure drop drives a turbine and in turn generates electrical power.
One issue is that the inlet pressure is only about double the outlet pressure. The second issue is the flow through these pressure reduction stations is only between 10-20,000 Sm^3/h.
The kinds of products that I found so far, require flows above say 50,000 Sm^3/h and pressure drop ratios of 4-10. I expect that with a ratio of 2 and a flow of 10-20,000 Sm^3/h it would only be possible to get between 100-500kW of power.
My questions are:
1. Can anyone confirm my comments regarding generating ability given my limits?
2. Has anyone out there used smaller expansion turbines to generate electricity? What was your experience?
3. Did you have to deal with surplus power storage? Regulating the power output in response to the demand? How was that achieved?
My questions are:
RE: Gas Expansion Turbine Generator
See:
http://actamont.tuke.sk/pdf/2004/n3/27pozivil2.pdf
Try to present the problem in Eng-Tips
Heat Transfer & Thermodynamics engineering Forum
regards, rasevskii
