Soldier Pile with Raker
Does anyone know where to find a design manual for calculating the sectional modulus for a soldier pile wall with a raker for a 14 foot high wall, soldiers at 7 feet on centre, raker about 2 feet from the top with a 50 psf surcharge?
RE: Soldier Pile with Raker
Try the Caltrans Shoring and Trenching Manual. Note, though, that shoring movement checks aren't performed, but you should perform one anyway.
http://www.dot.ca.gov/hq/esc/construction/manuals/OSCCompleteManuals/TrenchingandShoringManualRev12.pdf
If you want you can place a waler between piles and a raker every 14 feet with a roll chock. This will help excavation activity (more space for excavator).
Are you adjacent to an existing building? Prefer tiebacks over rakers in this situation.
VictorAK,
The raker acts as a strut (assuming that you've sized it correctly for the required loads). It's a straightforward problem for a nongravity wall. See FHWA guidance for determining braced wall earth pressures and anchor/strut loads here:
http://www.fhwa.dot.gov/engineering/geotech/pubs/if99015.pdf
Most use software to perform the wall analysis.
Jeff
