Sheet Metal Bend Notes
How do you "un-dangle" a sheet metal bend note?
Christopher Zona - Product Designer
Loretto, Ontario
RE: Sheet Metal Bend Notes
Chris, try right clicking the flat pattern view, click properties and un-check the display sheet metal bend notes. Then re-click it to make it active again. This should/may reset the notes to the default. You may have to close the property window before making it active again.
Regards, Diego
