Thickness is not defined in one or more shell
I am working on static analysis of a solid body. I have defined the material etc. But there is one warning sign due to which the simulation is not done.
The warning sign is "Thickness is not defined for one or more shells". I checked my FeatureManager tree but there is no shell feature. However I see there are a few surface feature like "surface extend", "surface cut", "surface fill".
Am I getting this error because of the surface features?
How to avoid this warning and go on for simulation? Please let me know.
I appreciate your help in advance.
RE: Thickness is not defined in one or more shell
You might consult help.
TOP
CSWP, BSSE
www.engtran.com www.niswug.org
"Node news is good news."
You can rt-click on the surface and select 'exclude from analysis'.
Then try re-meshing.
Ed
