Annotation To Drafting
Hi All,
I am creating a quick layout for some machines to be placed on our shop floor, it is nothing fancy. I am creating the machine footprints in sketcher.
I am identifying the machines by creating an annotation inside the box that represents each machine. Is there a way that I can carry this text directly into drafting?
I am creating the text by Insert >annotation >text >text
I apologize if this is a very simple question and thank you in advance.
thixoguy
thixoguy
RE: Annotation To Drafting
When you create the view, use the "view from 3D" function.
Catia Design|Catia Design News|Catia V5 blog
It appeared you were on a bit of a "holiday" for sometime, glad to see you are back.
thixoguy
No holiday - Just absent.
Thanks for the warm welcome back, though...
Is there anyway to do this when doing a view from 3D?
These "certain part bodies" - are they coming from an assembly, or a multi-body solid?
My understanding of "modify links" is limited to its use in conjunction with scenes. I have not heard of it being used to filter out part bodies.
When placing a view in drafting (except for a 'view from 3D') you can select the bodies and/or geometric sets to display in that view. Also can select the axis system to use.
If needed, after a view is placed we can modify its links to add/remove specific part bodies to that view. Comes in very handy for drafting.
OK, thanks anyway. Its not a huge deal, just thought if anyone would know you would be the one.
