Blind Bolt Bending Analysis
Does anyone know why within structural aerospace analysis the preference appears to be to ignore blind bolts in bending?
John.
RE: Blind Bolt Bending Analysis
What do you mean by "ignore blind bolts in bending"?  not perform a stress analysis of a bolt in a particular joint configuration?  not use such bolts in a highly eccentric joint? ignore them in a load share analysis? or something else?
Please post the detailed reason for your question, and details of your particular joint configuration, strap materials, loadings, etc.
As far as I know, blind bolts are fitted to interference holes. As long as the interference is intact, bending can be neglegted in most cases.
Dan
Bolt bending is not a function of hole fit, but of joint eccentricity as SWComposites infers.
Blind bolts are not preferred for large-eccentricity joints.  They lack the clamp-up capability of a traditional threaded fastener, and will fail prematurely in that usage.  That's why you can't find data or analysis for that failure mode; it's a bad design detail.
SuperStress
 Fastener bending occurs (or can occur) in non-interference shear joints.
That is a more elaborate answer to my interpretation of the OP question.
Dan
