proper handling of powdered flux for sudarc
the subject came up the other day. one person was saying they had to heat the flux before use and use while warm. another was saying they did not. one of the guys said according to Code it has to be. the comeback was, why, it has an ambient temperature preheat and the hopper is not heated. the manufacturer's bag only mentioned "baking" not the need to heat it prior to use; it could be used straight from the bag.
i am familiar with coated electrodes but have never run across this process, so can anyone shed some light on this for me.
tia
tia
Steven C
Senior Member
ThirdPartyInspections.com
RE: proper handling of powdered flux for sudarc
Hg
Eng-Tips policies: FAQ731-376: Eng-Tips.com Forum Policies
Fused fluxes can pick up surface moisture.
In either case, if the base metal is crack sensitive, you will want you flux to be dry and free of moisture.
Consult the manufacturer for their recommendations for proper flux storage.
Best regards - Al
just trying to educate myself on something new to me.
Hg
