SW2009 - Problem with creating 3D line tangent to helix
I used to be able to do this in SW2008 but have not been sucessful in 2009.  Can anyone advise me what I am doing wrong?
I create a helix.
I then open a 3D sketch, draw a random line. The endpoint is placed on the helix - so far so good.
Now I want to make the line tangent to the helix at that intersection point - it does not let me add the sketch relation.
Ultimately I am after a line perpendicular to the helix, but even in SW2008, it did not let me do that, the best i could do was draw a tangent line, and then draw another line perpendicular to that one.  I cant even do that in SW2009.
My old SW2008 files that were converted to 2009 still work.  I am trying to create a new one.
Any ideas?
RE: SW2009 - Problem with creating 3D line tangent to helix
Use "Convert Entities" to bring the helix into your sketch and constrain t that.  Make the converted helix a construction entity if you must.
Making a tangent to the parent circle is not the same thing since the helix angle is not parallel to the circle plane.
TOP
CSWP, BSSE
www.engtran.com  www.niswug.org
"Node news is good news."
Tick
Converting entities fixed this
thanks
