Altitude correction to pump performance curve
My question relates to submersibles and is not necessarily an NPSH question. If a pump performance curve has been determined at, for example, sea level and the pump will be used at a higher elevation, say 8000 ft above MSL, is is necessary/correct to de-rate the performance curve? I need an accurate curve so I don't want to simply neglect the difference in atmospheric pressure.
Tom
Tom
RE: Altitude correction to pump performance curve
Tom
I guess the NPSHr is given by Mfr accounting for 3% losses of head. In case the altitude increase, the NPSHa will tend to decrease.
One need to check if at higher altitude, NPSHa is still above (NPSHr + margin). If not, pump is likely to experience cavitation, leading to additionnal % decrease in head (I guess difficult to predict). This is not normal operation. Perf. curves are given for Normal Operation.
My opinion only
Rgds
Wimple
athomas236
As was pointed out above, its a differential head, so there can be no effect. Changes in densities of liquids at lesser atmospheric pressures (even if they might be appreciable) will not affect the pump head curve, as pump differential head imparted to any liquid is constant (when neglecting viscosity affects), however the suction and discharge pressures would change, if a change in density was significant (although that is highly unlikely).
Of course any pressures read with a differential pressure gage relative to atmospheric pressure would change due to altitude difference.
So, recalculate NPSHa and Power requirements. Power requirements are increased at higher altitudes, the specifics vary with different types of drivers.
"Pumping accounts for 20% of the world's energy used by electric motors and 25-50% of the total electrical energy usage in certain industrial facilities."-DOE statistic (Note: Make that 99% for pipeline companies) http://virtualpipeline.spaces.live.com/
I agree with you.
What about the following scenario : the pump is quoted at sea level. There is sufficient NPSH margin for operation. The design of the pump is frozen in these conditions.
Then the pump is relocated (at higher altitude) leading to lower NPSH margin.
Is it possible that this lead to an increase of "permanent cavitation" ?
Therefore what is the definition of permanent cavitation (is it 3% losses of head) ? Is it possible to agree with Pump Manufacturer, to redefine pemranent cavitation limits, let say 5% head losses and then revisit the Pumps curves?
What do you think?
Rgds
Wimple
Yes, of course, if the NPSHa at installation altitude is lower than the pump's published NPSHr (defined at 3% head loss with cool water at <presumedly> sea level atmospheric pressure).
At some new altitude, the only thing that appears to change would be the atmospheric pressure. We have to ask, what effects if any that would have on the pump head curve and the NPSHr curve. It wouldn't appear to have any effect on the pump curve. Now, would NPSHr be affected? At any flowrate, would the onset of cavitation be any different when at altitude than when at sea level? If you had a closed system at sea level and at altitude, no. Any supposed difference would have to be attributed to a change in atmospheric pressure. If you use absolute pressure units, it seems apparent to me that the only difference would be accounted for when solving for NPSHa, so nothing else to consider. NPSHa is less, margin is less, so using the NPSHa solution method covers us quite well.
Yes you could redefine the NPSHr curve onset of cavitation for some arbitrary difference in %head loss, 3%, 5%, 10%... , but why do that when the normal NPSHa method already considers this and tells us everything we really need to know. We would wind up with an infinite number of pump curves for just one pump for all altitudes(??) We could just as easily say we should define pump curves for all possible combinations of fluids, each with different vapor pressures, or alternatively, for one fluid at all its possible vapor pressures. Much easier to just do one for cool water at sea level and remember to operate it within the limits of NSPHa > NPSHr.
