High speed milling
High speed milling
I would like to know from any of you CNC programmers how you approach high speed roughing with cavity mill. We machine things like 303 stainless, 17-4 PH, P20 and 7075 aluminum.
I would like to achieve efficient metal removal, and lately we've been using some of the guidelines from the cutter manufacturer (OSG)and are getting some results, like .250 deep with a 3/4" dia. running at 5200 RPM, and 100 IPM in 303.
The issue I'm interested in is keeping the tool engagement angle to a level that you can sustain the mumbers above without breaking the cutting tool, especially as you approach closed corners. Yes, there are corner slow-down settings, and there is trochoidal, but you have to be very careful especially in the corners. The new "corners" tab under the "cutting" menu helps to make smoother "radii" in the toolpath stepovers and is an improvement.
I'd be interested in what result you may be getting, especially in the harder materials.
