Extrude error in configuration
Open up this part and between the two configurations. You'll notice the warning that pops up in one because the sketch is no longer in the right place. But why? The sketch was created using convert entities---shouldn't it remain in that channel? So either I'm seriously misunderstanding configurations or something strange is going on.
RE: Extrude error in configuration
If all the sketch elements are deleted and replaced with a full outline of the recess, the feature rebuilds without throwing an error message, but still switches position.
You should submit this to your VAR.
- - -Updraft
