Aliminum Tubed Exchanger
Hello to you all. I have a semi-hypothetical question. We got an RFQ for a fixed tubesheet cooling water exchanger, carbon steel materials, moderate size, temps and pressures.
One option was for aluminum tubes and aluminum-clad tubesheets, seal welded.
We chose to no-quote this option based on lack of experience, but I am wondering if this is any problem to do.
I figure the engineering side would be pretty straight forward, since as the apps engineer and I agreed "its just numbers".
I am guessing the tubesheets would be available as det-clad, no big deal.
Assuming we had a procedure (and a qualified welder) for the tube-TS welding, is fabricating aluminum any problem? We did discuss maybe using aluminum baffles instead of CS.
Any experience out there to share?
Mike
Mike
RE: Aliminum Tubed Exchanger
Mike
