Looking for foam sensor
We have a 4" line that normally contains a water/methanol vapor flow of 1800 lb/hr at 230 deg F and 4 psig. During process upsets, a soap-like foam fills the line. We would like to use a sensor that would detect the foam flowing down the pipeline(prefer non-contact since the process tends to build a tar-like deposit). Does anyone have experience with a sensor application like this?
Thanks in advance for any recommendations.
RE: Looking for foam sensor
http
we are working on a coker revamp and we are using the two possible technologies for level measurement, that are NBS and continuous gamma level.
best regards
mariano
