Help for PATRAN needed
Hi all, I am in troubles with PATRAN. I need to read a .op2 file of huge size (> 4 GB), and PATRAN isn't even able to see it in the file selection window. Since the run to generate it takes too long, how can I override this inconvenience? Thanks , bye.
Spirit
Spirit
'Ability is 10% inspiration and 90% perspiration.'
RE: Help for PATRAN needed
your output file is really huge!
I suggest you 2 possible solutions :
1. run the solution again with less output request in
subcase select. E.g. you may sweep the request of
SPCFORCE if you really do not need it.
2. If you use PATRAN with version 9.0 or later, then you
may use XDB format instead of .op2 for data output. To
my know, the XDB format is faster then op2, because it
doesn't load all the file/data in to the memory.
Hope it would help you
regards
I would recommend the two suggestions by zuardy, especially "attaching" the xdb file. This will not read the results into Patran, merely reference to it. Also, I would like to suggest two other options.
3. If you have more than 1 subcase in the run, lessen the number of subcases
4. Request results for only subsections of the model you may be interested in. Make multiple runs requesting output for different subsections to verify fidelity of the entire model.
The results file sounds awfully large!
-George
