Edit > Object Display > Face
Experts,
This question has cropped up lots of times over the years.
Once the color of a face has been changed by filtering on type 'face' is there any way that this can be undone?
Users are changing face colours to aid identification during construction. Once the part is complete, we change the color to a uniform color all over. Selecting type body will only change those faces that haven't had a unique color applied - The obvious workaround is to select all the faces rather than the body.. the users just think this is a little untidy...
Any ideas?
NX5/6
Any ideas?
NX5/6
RE: Edit > Object Display > Face
Edit -> Object Display...
...select the BODY, hit OK, select the desired color, or use Inherit and select one of the faces which is still the desired body color, open the 'Settings' section of the dialog and toggle the 'Apply to All Faces' option to ON and hit OK.
That should do it.
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
J
There may be different colors applied to the faces. For example the machined faces vs. the casting faces.
John R. Baker, P.E.
Industry Sector
Cypress, CA
This gets turned ON when the colors of objects are changed at the assembly level.
Specialty Engineered Automation (SEA)
http://www.sea4ug.com
a UGS Foundation Partner
