Exporting an exploded assembly from ERA to STEP?
I have to provide a STEP file of an assembly, but with the components exploded.
I figured I'd do it in the Explode/Render/Animate environment... But when I try to save the exploded configuration as STEP, SE tells me "The model contains no bodies. An output file will not be generated".
I would have prefered not to change the assembly constraints, but it looks like it's the only possible way to do this... Unless anyone has a better idea?
Thanks.
Thanks.
RE: Exporting an exploded assembly from ERA to STEP?
AFAIK that's not possible. The exploded view is just what
is says a view the assembly itself is not physically put
into bits and pieces
dy
Thanks for your response.
KENAT,
Have you reminded yourself of FAQ731-376: Eng-Tips.com Forum Policies recently, or taken a look at posting policies: http://eng-tips.com/market.cfm?
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
