N2 to Modbus Multidrop?
I'm currently working with a Johnson DX-9100-8454 PLC unit and am trying to interface it in a multi-drop style Modbus RTU network.  Problem is, the only RS-485 protocol on the PLC unit is an N2 bus, which I believe is proprietary to Johnson Controls.  Spoke with one of their application engineers and evidently I probably need to find some sort of converter or gateway to make this work, which of course Johnson doesn't manufacture.  Does anyone know of a place to pick up a N2 to Modbus converter or have a different idea of how this can be done?
Thanks for your time,
Steve
RE: N2 to Modbus Multidrop?
How about these?
If you need a MODBUS master interface:
http://cgproducts.johnsoncontrols.com/cat_pdf/publ3544.pdf
If you need a MODBUS slave interface:
http://cgproducts.johnsoncontrols.com/CAT_PDF/PUBL3543.pdf
xnuke
"Live and act within the limit of your knowledge and keep expanding it to the limit of your life." Ayn Rand, Atlas Shrugged.
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips.
