What will be the heat input?
Furnace Details
Zinc capacity - 294 MT at 452 deg C
Kettle size - 7 (L)x 2.5 (W) x 2.5 (D)meters (50 mm thick)
Burner - 4 nos Diagonally opposite.
Furnace casing (length) - 8.16 meters
Furnace casing (width)  - 4.07 meters
Furnace casing (depth)  - 2.79 meters
Furnace gallery between kettle & insulation - 300 mm
Throughput inclusive of jig weight - 8 MT / Hrs.
Combustion air blower - 10 hp - 2400 Nmtr3/hrs
What should be the burner capacity in kW?
What is the heat input needed to run this furnace?
RE: What will be the heat input?
How is it that you know the combustion air blower capacity and not the burner capacity?  What type of fuel? If it is natural gas then you could back into a theoretical maximum burner capacity by assuming 10:1 ratio of air to fuel.
dear dvd
I have two types of burners one with 322 kW & other with 586 kW, plz tell which suits best to this furnace & why?
What will be the heat input in Kcal/hr/burner?
galvanizing
Even if someone solved the problem, how would you verify that what you were told was right?
If you read through thread391-251852: Forced Convection, you'll notice there are a number of links to websites.  I suggest you visit those websites and try solving the problem yourself.
Patricia Lougheed
Please see FAQ731-376: Eng-Tips.com Forum Policies: Eng-Tips.com Forum Policies for tips on how to make the best use of the Eng-Tips Forums.
