Determining the angle of belt wrap at drive
Are there any tables and/or formulaes which may assist us in solving this problem? We require the angle to determine the k factor in the formula Tm (Slack side Tension) = k X Te. Where Te is 1788.27 N
Any help would be appreciated
RE: Determining the angle of belt wrap at drive
It's possible to do it with geometry, but it's usually much faster to lay it out, or take a photograph.
Mike Halloran
Pembroke Pines, FL, USA
If it's a V-belt drive don't you just use the manufacturers catalogue to select suitable belt drive configurations??
