MMM-A-132
MMM-A-132
MMM-A-132
I've been asked to find a good adhesive to bond a phenolic strip with an aluminum door, but the adhesive needs to conform to a federal spec MMM-A-132. Any suggestions?
RE: MMM-A-132
Most manufacturers will state if their products are qualified to MMM-132-A. However you need to realise that the data generated by MMM-132-A does not contain any useful design data whatsoever.
My advice would be to concentrate on the surface preparation especially for the aluminium.
RE: MMM-A-132
Many of the adhesives under MMM-A-132 are also qualified for MIL-A-25463. It is aimed at adhesives for sandwich construction, but maybe some of the data at the MIL spec may be useful to you.
RE: MMM-A-132
Not sure if you have specific strength requirements to meet, but we have used Hysol EA9320NA room temperature cure paste adhesive with AC-130 Sol-Gel treatment for good results on aluminum.  The EA9320NA product data states that it meets the requirements of MMM-A-132 but it is not listed in the QPL.
I don't know if this adhesive is compatible with phenolic material, or what surface prep would be required.
