Companies Doing Automated Weld Overlay on ID of Columns and Vessels
I'm looking for more companies that do automated (mechanized) overlay welding on the ID of columns and pressure vessels using single or twin wire GMAW.
We have use WSI (now Aquilex) and JV Industrial. Looking for other still in business. Rentjes gone a long time ago, GE Welding Services (now part of Aquilex).
Any others?
Any others?
RE: Companies Doing Automated Weld Overlay on ID of Columns and Vessels
klad manufacturing in houston
although i think they both use subarc flux core and ribbon
"IN THE FIELD"
I'm familiar with RC Tech, Universal and Klad, they only do shop work with weld automated or mechanized weld overlay.
I'm looking for companies that erect mechanisms inside the vessel and do automated welding using GMAW. I had heard of PCI but was not sure they did field work So thanks for that one.
Welding or high Cr grades produces a lot of hex Cr near to the weld. When you do it inside of a vessel, well you get the idea.
The latest revision of the regs does not allow the use of PPA, it must be an engineering solution.
I know one company that has stopped doing field overlay work because of this.
Plymouth Tube
