ANSYS Workbench in Inventor 2010 Pro
I'm trying to do a stress analysis on a part I'm working on and trying to access the ANSYS Workbench Add In. However I can only access the Inventor Default Add In menu and not the Pro Menu. Any suggestions. Thanks in advance.
RE: ANSYS Workbench in Inventor 2010 Pro
Inventor 2010 no longer uses ANSYS.  Not sure what you mean by, "...not the Pro Menu"?
Are you using Ribbon interface or Classic?
FEA should be under Environments.
I has some problems where it wouldn't show up for me and I still had 2009 installed.  I had to to a Clean Uninstall of 2009 and 2010 per Autodesk instructions (including editing of Registry) to get 2010 Pro working correctly.  (I was also missing Inventor Studio)
