Display Style Transparent in Drawing
does anyone know how to view a saved display style in a drawing?  I have an assembly with some compenents set to transparent and others set as shaded.  I can't seem to find this style in a drawing.  All I can do is an assembly that is either fully shaded or with lines (hidden, no hidden...)
RE: Display Style Transparent in Drawing
What version of Pro/E are you using. Shaded views on drawings was added in WF3. I only have access to WF2 where I work, I was not able to do what you are asking for.
Peter Stockhausen
Senior Design Analyst (Checker)
Infotech Aerospace Services
www.infotechpr.net
I am learning WF4.  Shaded views are fine, but views with both transparent and shaded or line I cannot do...
Not having your version available, but remembering what I learned in using WF3. What you ask might be possible using the various display style, simp rep, and combo settings.
Peter Stockhausen
www.infotechpr.net
I think what I am looking for is how to choose my custom made 'style' view in the drawing.  When I go to the DRAWING VIEW properties window, I can select my custom simplified rep, my exploded view, orientation, but I cannot find the style that I made with transparencies.
I have tried to use a combination state but even that does not show transparent components  that I have in the assembly...
