Solid5 coupling problem for piezo stack
Hi Guys,
For my research i want to simulate the total deformation of a piezo stack. For this I use SOLID5 elements.
I manage to successfully simulate the deformation of one piezo element.
If i want to model a stack of piezo element i get into troubles when i apply the VOLT DOF to the elements. Because the elements are stacked they share the same nodes for the Positive VOLT DOF and Ground VOLT DOF (The nodes between Piezo 1 and 2).
(Stack of two piezoelectric elements)
| 1 | 2 |
Do i have to mesh the two volumes separate and then define the VOLT DOF?
Is there another way to couple the two SOLID5 elements?
Thanks!
Christian
| 1 | 2 |
Quote:
FINISH
/CLEAR
!/plopts,info,3 ! Use multi window legend
/com ** ==========================================
/com ** DEFORMATION OF A PIEZOELECTRIC STACK
/com ** BY ...
!Dimentions one piezo 20*20*2 mm
h_PZt = 20E-3 ! Height of PZt (along y axis)
w_PZt = 20E-3 ! Width of PZt layer (along x axis)
t_PZt = 2E-3 ! Thickness of PZt (along z axis)
n_PZt = 2 ! Number of PZt in Stack
/prep7 ! Enter preprocessor
/title, Total Deformation of a Piezo Stack
/com ** DEFINE ELEMENT TABLES
ET,1,solid5,3 ! Element 1: 8-node coupled field solid with all DOFs used for PZt
/com ** PZ26 PIEZO ELEMENT Z-POLARIZED MAT PROP
/com
/com ** STIFFNESS
TB, ANEL, 1 , 1 , 0
TBDATA, 1, 1.6800E+11 , 1.1035E+11 , 9.9905E+10
TBDATA, 7, 1.6800E+11 , 9.9905E+10
TBDATA, 12, 1.2264E+11
TBDATA, 16, 2.8825E+10
TBDATA, 19, 3.0126E+10
TBDATA, 21, 3.0126E+10
/com ** PIEZO MATRIX
TB, PIEZ, 1
TBDATA, 3, -2.8012
TBDATA, 6, -2.8012
TBDATA, 9, 14.6913
TBDATA, 14, 9.8568
TBDATA, 16, 9.8568
/com ** PERMITTIVITY
EMUNIT, EPZRO, 8.85E-12
MP, PERX, 1 , 829
MP, PERY, 1 , 829
MP, PERZ, 1 , 701
/com ** DENSITY
MP, DENS, 1 , 7.70E+003
/com ** DEFINE GEOMETRY
z = 0
*DO,I,1,n_PZt ! Repeat for each actuator
BLOCK,x,x+w_PZt,y,y+h_PZt,z,z+t_PZt
z = z+t_PZt
*ENDDO
/PNUM,Volu,1 ! turn on numbering and colours for material types
VSEL,S,VOLU,,1 ! Select volume 1
TYPE,1 ! Use element table type 1 for meshing
MAT,1 ! Use material 1 attributes for meshing
VMESH,ALL ! Mesh
VSEL,S,VOLU,,2 ! Select volume 2
VMESH,ALL ! Mesh
VSEL,ALL
NSEL,S,LOC,Z,0
CM,t_elec,NODE ! Top electrode node component
CP,1,VOLT,ALL ! Couples volt DOF on top electrode
Thanks!
Christian
RE: Solid5 coupling problem for piezo stack
Probably the "7.13 Sample Piezoelectric Analysis" from "Coupled-Field Analysis Guide" would help. Especially the part where they set up the local coordinate systems.
Thanks for you reply!... It is always better then no reply
I solved the problem by making the model more accurate... I added a top and bottom nickel electrode and a Epoxy layer to add the components together...
Cheers.
